Increase M Comp Table Size (X-Axis)
I'm trying to plug in numbers for my x-axis in the M-comp table and notice it only goes up to 8 while my travel (actual not radius) is 12.5". I would like to get the full range of my x-axis leadscrew and thus increase this table size to 12.5. I have my soft limit for x-axis set to -12.5" in the Wizard. Is there a way to do this?
Re: Increase M Comp Table Size (X-Axis)
post a fresh report.zip
please explain another way what you are trying to accomplish. thanks,
The M comp table for the x-axis only goes up to 8.000 and I need it go all the way to 12.5000 in order to compensate for the entire length of travel of that ball screw. The M comp table is making the calibration worse once I plug in the actual distances traveled on the x-axis. I'm getting fairly accurate readings out of the box without using M comp (accurate to 2-3 decimal places and consistent to 4th decimal place with each repeat command). I was wondering if not having numbers in the M comp table from 8.000 to 12.5000 was somehow causing the M comp calibration to make my numbers worse. Attached is the latest report.
- report_0035FF8A1904-0730203595_2021-04-13_02-25-23.zip
- (753.16 KiB) Downloaded 73 times
Any word on what I need to do to increase the table size for the X-Axis from -8 to -12.5? The X-Axis soft limit is set to -12.5 in the Wizard and the Z-Axis soft limit is set to -15.5. And now both M Comp tables don't go up to the soft limits on each axis (the Z-Axis table stops at -15.0). There's got to be a way that the M Comp table size is editable or at least matches the limits set in the Wizard.
IIRC, you can open the file up in Excel and add the additional position entries and then you'll be able to add the deviations in CNC12.
Thanks tblough. I didn't see a file called IIRC but one that shows up when I first click on the M Comp tab. The program said "Warning: file cnc-z.tab Travel limit settings do not match the number of entries." I opened up that file and the one for the X-Axis, editing them accordingly, saved them and then opened up CNC12 back to the M Comp area but still shows same -8 for X and -15 for Z. I made sure to close out of CNC12 and the files themselves before opening back up to see if changes were made but no luck.
If you want to edit the files, see http://www.cncsnw.com/LaserComp.htm
You might find it easier to just exit CNC12, delete your cnc-x.tab and/or cnc-z.tab files, then restart CNC12. Next time you go to the M Comp table, CNC12 will make new files that match the current travel limits.
IIRC= If I Recall Correctly
Deleting those files and then restarting CNC12 worked flawlessly for both X & Z-Axis. Thanks guys!
Thanks Marty for the acronym clarification.
