Jog button in VCP sticks on
jumps4
CNC Control System Serial Number: 38d2697ca033-0611180974 mpu12
Re: Jog button in VCP sticks on
Post by jumps4 »
I'll be back to testing this afternoon.
I know windows update didn't cause the issue. It did it from the beginning before the PC was ever put on the internet.
Windows update caused a loss of administrator privileges. I have to go through and make sure the setup for Acorn has not changed since these last updates.
I will return to post whether it is fixed or not.
Steve
No Brains, No Headaches...
jumps4 wrote: Tue Apr 13, 2021 10:23 am I'll be back to testing this afternoon.
Steve
It may be your monitor. That's why we suggested you disconnect the USB cable from it.
jumps4
Post by jumps4 »
Disconnecting the monitor USB cable and the ShuttleXpress USB cables did not resolve the problem even after a reboot.
repeated clicking of the jog button would make it stay on some times.
I looked up how to remove touch screen driver and was directed to:
Press the Windows logo key + X.
Select Device Manager from the list.
Click the little arrow next to Human Interface Devices to expand the list.
Click the touch screen driver,
Right-click, and select Disable from the list.
Click Yes on the dialog box that asks if you are sure you want to disable the touch screen driver
There were 2 human interface drivers running and since the mouse and keyboard drivers are in a different location I disabled both.
On reboot windows installed the drivers even though the devices were disconnected. If this fixes the problem the driver is the cause and not the actual touch screen itself.
So far I have not been able to get it to act up.
I clicked until my finder hurts ...
I will test more later
Steve
jumps4
Post by jumps4 »
after disabling the drivers and powering down everything , on restart windows did not re-enable the drivers.
will see
Steve
jumps4
Post by jumps4 »
I see that planar monitor uses the windows tablet settings and driver to control it. Planar has no driver for my touchscreen. PCT2235
I went into "tablet settings" and clicked on "never use this device as a tablet" also
jumps4 wrote: Tue Apr 13, 2021 3:21 pm I see that planar monitor uses the windows tablet settings and driver to control it. Planar has no driver for my touchscreen. PCT2235
Keep us posted.....
bluestratus
Post by bluestratus »
Any updates to this? Is it resolved?
Having the same issue with jog sticking when i click the mouse button, no touchscreen installed on my system.
bluestratus wrote: Thu Apr 29, 2021 8:24 pm Any updates to this? Is it resolved?
You mark this resolved? Did you fix it? If so, please state what you did to bring closure to this...
jumps4
Post by jumps4 »
I have had to stop working on this due to a few very large jobs.
As of my last tests I had no problem but I do not feel i have tested enough to declare it fixed.
I will try to conclude testing as soon as I can.
Steve
jumps4 wrote: Fri Apr 30, 2021 9:33 am I have had to stop working on this due to a few very large jobs.
Steve
Let's not mark it resolved.
Make sure you have a quality mouse, updated drivers, tried a different mouse. Mechanical buttons on a mouse can "bounce" causing what would seem to be multiple presses.
When you do report back, please start your own thread. ALSO PLEASE post a fresh report.
