Hello
I receive an error message 913 but I would like to know why?
Here is my program and a report.
I want to make a room with 5 other wcs, but nothing wants to open.
Do you have any idea on this.
thank you
Alain
913 ERROR
913 ERROR
- g54 to g59 #1.nc
- (10.24 KiB) Downloaded 80 times
- report_E415F6F138CC-1119204064_2021-04-04_18-07-17.zip
- (628.28 KiB) Downloaded 66 times
Re: 913 ERROR
Thank you that corrected the error.
here is another error that I do not understand 907 with an x which exceeds the limits.
when I look at the graph of cnc12 I see a gap between the 3rd piece (g56) and the 4th (g57). ?
https://photos.app.goo.gl/6mGMbHs4NJ2BuE1N6
Re: 913 ERROR
From your report file:
When you set your part zeros, did you mean for G57 to be to the left of G54, G55 and G56?
If not, you need to set the G57 part zero position where you want it.
The "907 X axis travel exceeded" message is telling you that, to run your job the way you have it set up, the control would have to go outside the machine's travel envelope.
Axis Origin Origin Origin Origin Origin Origin
#1(G54) #2(G55) #3(G56) #4(G57) #5(G58) #6(G59)
X 4.56303 10.94388 17.32472 -14.57997 -20.96097 -27.34197
Y 83.13407 83.13407 83.13407 83.13407 83.13407 83.13407
Z -9.79691 -9.79691 -9.79691 -9.79691 -9.79691 -9.79691
Re: 913 ERROR
my g 54 and the home piece are those furthest to the left in the assembly.
Why the g57 would be the starting point of the work.
In my cam I give g54 the starting point and then 6 other locations in total to do with the maximum of 6 g of location that cnc12 allows me.
thank you
alain
thank you
alain
