Regen Blower specs for 4x4 Vac Table
tuffduck
Post by tuffduck »
Can anyone advise if this blower would work for a 4x4 table? Thanks
2HB630H16-2.2KW high pressure fan
2.2KW high pressure fan, vortex vacuum pump, high pressure fan size, high pressure fan parameters
Product model: 2HB630H16
Structure: single impeller fan
60hz
Power: 2.2kw
Voltage: 200-240Δ 345-415Y
Flow rate: 345m3/h
Vacuum pressure: -200mbar
Compression pressure: 195mbar
60HZ
Power: 2.55kw
Voltage: 220-275Δ 380-480Y
Flow rate: 415m3/h
Vacuum pressure: -170mbar
