first hole problem
yuyu
CNC Control System Serial Number: C147272
first hole problem
Post by yuyu »
hi everyone
my concern is that when I load my gcode in cnc12, the card does not make me the first hole while my simulation in solidcam is ok no problem with the gcode I do not understand why.
this only happens for the first hole, all others are ok.
thank you for your help I put here a screenshot as well as the gcode.
P1.txt
(12.46 KiB) Downloaded 72 times
Re: first hole problem
hi, its not in the g code , go back to your cad cam system and make sure you selected all the holes.
and please always post a fresh report.zip file. thanks, k
Also try setting CNC12 Machine Parameter 2 to a value of 2.
http://www.cncsnw.com/faqCAM.htm#2.1
yuyu
Post by yuyu »
Thank you very much.
clear and precise answer as I like them, my problem is solved
Rensoc
CNC Control System Serial Number: 4119
Post by Rensoc »
I was just working through the same issue! Changing the Parameter worked. Thanks!
