Setting soft limits
Re: Setting soft limits
According to the manual Marty posted and your pics the drives are set to 2000 steps per rev. Look at the chart on the drive itself. Switch 5,6,7 & 8 in your pic is off, on, on, off, that’s 2000 steps per inch or a micro step factor of 10. I think your turn ratio is not correct and you shouldn’t set steps per below the minimum recommended number of 1600. I think something is still off.
E415F6F70BC3-0318203049
If the drive dip switches are unchanged and therefore still set to 2000 steps you MUST match this in Acorn's Wizard by setting Steps / Revolution at 2000 as both Marty and Shawn have stated. Once set, this does not change
To achieve correct distance commanded vs actually travelled, you need to change the Overall Turns Ratio on each Axis. You should NOT adjust steps either on drive or Acorn as they must always match
hope this helps
hope this helps
Hope this helps
Nigel
Nigel
Sorry Shawn, I didn't see you had already replied
Hope this helps
Nigel
Nigel
No worries at all, I'm glad someone else chimed in. I'm hopeful neowalla will understand how he has it set up is not correct and make the necessary changes to get his system in order. It's only going to create problems later if he doesn't. Match the steps per rev on both Acorn (in the wizard) and the drives and then set the Overall Turns Ratio for your mechanical drive system.
Can't agree enough with you on this point Shawn....ShawnM wrote: ↑Sat Apr 03, 2021 5:11 pmNo worries at all, I'm glad someone else chimed in. I'm hopeful neowalla will understand how he has it set up is not correct and make the necessary changes to get his system in order. It's only going to create problems later if he doesn't. Match the steps per rev on both Acorn (in the wizard) and the drives and then set the Overall Turns Ratio for your mechanical drive system.
