Bridgeport Interact 412 Retrofit ATC Help
jpmsteadi
CNC Control System Serial Number: E415F6F1121A-1204204111
Re: Bridgeport Interact 412 Retrofit ATC Help
Post by jpmsteadi »
Perhaps you would be able to use a latching relay? and send an additional signal for carousel out?
Attached is a copy of "acorn_mill_plc.src" with the carousel in/out solenoid logic changed, to work with a single-coil spring-return solenoid.
You should be able to install the update using F7/Utility -> F2/Restore Report.
I am fairly certain that these changes will survive future use of the Wizard.
Let me know if this solves your carousel in/out issue.
report_PLCUpdate_AcornBridgeport412_210330.zip
(172.46 KiB) Downloaded 81 times
RefinedFab wrote:Seems it loses its tool bin location when i power everything off and start it back up. Actually i think it remembers the bin location it is at and what tool is in the spindle but it starts spinning the carousel several turns until i stop it waiting on mem 64 like its waiting on a home location sensor?? Any idea? What i have to do to get around it is initialize the ATC but that resets all my bin/tool numbers
This is probably because the code in InitialStage that is supposed to load the previously-saved carousel position and putback location is conditional on ATCType_W==1, but ATCType_W does not get set until after InitialStage has finished its one and only scan.
To work correctly, the code in InitialStage would have to test SV_MACHINE_PARAMETER_830 instead.
Attached is an update with that change.
report_PLCUpdate_AcornBridgeport412_210401.zip
(172.49 KiB) Downloaded 80 times
RefinedFab
CNC Control System Serial Number: (7804732D2417-0529192027
Post by RefinedFab »
Hats off to cncsnw! He got the bugs worked right out of the ATC.
This retrofit was quite the endeavor for me. I bought it off eBay, sight unseen for basically scrap price. Drove 300 miles to chattanooga, TN to rig it onto my trailer and nurse it home. Had a buddy unload it in my shop with a forklift and started cleaning it up 2.5 years ago. Made it's first chips less than a year after and has performed flawlessly Finally getting the atc to work has been very intimidating so I kept putting it off until I got tired of looking at the lonely ether1616 board sitting on the shelf
Anyway here are some glamour shots of a few recent parts. I tried to load videos but it wouldn't let me...
Not bad for a 30+ year old machine ... Still rock solid and getting run everyday, thanks centroid and those who helped get this done! This is a pretty awesome community with tons of knowledge and members who are eager to help out!
I'm now looking for the next project because 2 vmc's is better than 1😃
Very nice! Beautiful parts!
You upload the video to YouTube and then share a link here
Please do so, showing the machine, it running and pan to the operator's display
Post to the Success Stories forum: viewforum.php?f=57
