as I previously said,
ALL info will come at once
Wil
Milling Issue
Re: Milling Issue
nothing in cnc12 or computer this is going to cause this. this is a losing steps issue.
thanks for posting the report.zip, one big red flag is the values you have to overall turns ratio (motor revs per inch) which you have set to .2853 for X and Y
there is pretty much no way that is going to work, this is a total mechanical overdirve of the machine and the motor will not be operating in its happy zone. so either you have this number wrong or the machine is of not a good design. review / re measure .. when you turn the X and Y axis motor BY HAND one revolution how far does the machine move?
fyi typical router overall turns ratios are in the 2.5 to 1.5 range and milling machines are in the 5 to 10 range.
- CNC Control System Serial Number: 78047383DD52-0131191593
Re: Milling Issue
Hi Marty,
Here's the missing info attached.
Homebuilt CNC from a Greenbull kit (buildyourcnc.com) https://buildyourcnc.com/Item/cnc-machi ... 4X-milling
The acorn, power supplies and stepper drivers are all housed in a steel server case with 6 fans for air flow.
The spindle is not controlled by the Acorn yet, but I will do that once this issue is resolved
Chain drives for x and y axes , and yes they are tensioned properly and not the cause of the issue.
Note: The schematic shows a separate power supply for each axis, at present ALL AXES share the AIKS 320 watt 36 volt power supply.
I will receive and wire in the other two supplies on Monday
Note 2: The Acorn is mounted on 1 inch standoffs
Note 3: I use a breakout board for the DB25 connections
- sausages2.cnc
- cnc cut file
- (31.6 KiB) Downloaded 79 times
- Nema34stepper.pdf
- Nema 34 steper (x, y and z)
- (119.39 KiB) Downloaded 101 times
- CW8060_driver.pdf
- stepper driver(x,y and z)
- (591.56 KiB) Downloaded 93 times
- report_78047383DD52-0131191593_2021-03-28_15-25-33.zip
- current report
- (622.19 KiB) Downloaded 82 times
Re: Milling Issue
Based on your stepper motor information, the best operating voltage would be 64VDC
square root of 4mh x 32 = 64
I would be running a 48VDC power supply
From your drive manual, the MAX Pulse signal frequency is 75hz
SO you need to go into the Wizard, ADVANCED TAB and CHANGE it, currently you have it set to 100,000KHZ
The Wizard's minimum is 100,000hz so go into Parameters
F1 Setup
F3 Config
Password 137
Go to paramete 968 and change it to 30:
P968 = 12.00000 -
Acorn Step and Direction Frequency in (Hz) 0 = 200000 Hz
3 = 400000 Hz
6 = 200000 Hz
12 = 100000 Hz
30 = 40000 Hz
60 = 20000 Hz
100 = 12000 Hz
Change the frequency and retest.
F1 Setup
F3 Config
Password 137
P968 = 12.00000 -
3 = 400000 Hz
6 = 200000 Hz
12 = 100000 Hz
30 = 40000 Hz
60 = 20000 Hz
100 = 12000 Hz
Re: Milling Issue
Hi Marty,
Could I run all 3 axes off of one 48v supply? ie 600W?
Re: Milling Issue
Or a single 64volt supply since I have to buy a new supply anyway?
Re: Milling Issue
Yes, that should be ok.
DO test with the lower frequency.....
If you make changes in the Wizard afterwards, the wizard will overwrite it and you'll have to change it manually again.
Re: Milling Issue
Hi Keith,
The X and Y axes are controlled by a chain drive sprocket
pitch angle drive sprocket = 0.25
14 teeth on drive sprocket SO 0.25 x 14 = 3.5" travel per revolution, so 1/3.5 = 0.2857 revolutions per inch,
These values were tweaked during calibration and this machine has been cutting accurately for some time
on large and small work pieces
So you are you saying that the drive sprocket is too large(too many teeth) ?
Wil
Wil
Re: Milling Issue
Hi Marty,
I don't understand this
You said that
so set Acorn Step and Direction Frequency P968 = 30 which means 40,000 Hz
I have no Idea how these 2 numbers are related
Wil
You said that
Wil
martyscncgarage wrote: ↑Thu Apr 01, 2021 11:43 am Based on your stepper motor information, the best operating voltage would be 64VDC
F1 Setup
F3 Config
Password 137
P968 = 12.00000 -
3 = 400000 Hz
6 = 200000 Hz
12 = 100000 Hz
30 = 40000 Hz
60 = 20000 Hz
100 = 12000 Hz
Re: Milling Issue
Its the maximum speed the drive is capable of receiving the step signals from Acorn.
You have old drives. Mach systems worked on lower speeds.
It might be beneficial for you to consider upgrading to newer drives that can accept faster pulse train input.
