Spindle Motor Recommendations
Re: Spindle Motor Recommendations
tblough wrote: Sat Jun 05, 2021 8:14 am That's a 3450 nameplate motor. I'd be careful running it much more than that. 1800 rpm motors can usually get away with running double the nameplate because manufacturers usually make a 3400 rpm motor with the same components.
Exactly. Consult with the manufacturer to see what the MAX RPM rating of the motor is. Let them know you are using it with a Variable Frequency Drive and wish to increase its speed.
It "looks" like a standard duty motor, not an inverter duty rated one.
jpmsteadi
CNC Control System Serial Number: E415F6F1121A-1204204111
Post by jpmsteadi »
For sure! It is a 3450 nameplate RPM motor. It is inverter rated, I am running it at like 78hz to get that 7k rpm. It has a 1.62 ratio pulley on it, so when the spindle is at 7k the motor is only spinning 4350 rpm, so not too much over the nameplate. When I bought it the ebay ad said it was rated for 5400 rpm, but on the motor I can't find that anywhere. I didn't pay much for it. I am hoping by keeping it cool and only barely running it over the rated RPM I will be okay. If it ends up dying Ill replace it with a more proper motor.
It does say its inverter rated though. 10:1 VT 2:1 CT.
Call Marathon with the model number and ask the rated RPM.
