I've send and e mail but still no response from them
Gecko drives gr214v (Resolved)
- CNC Control System Serial Number: Acorn-2631
Re: Gecko drives gr214v
It will be days before you get a response. See cnckeith's response to you.
Thank you Marty.. I've tried the db25 BOB and the communication with the gecko drivers works fine.. Don't know why the signals form the acorn headers interfiere with the gecko, but using the db25 they can talk with no problemmartyscncgarage wrote: ↑Mon Mar 29, 2021 4:26 pm Use the DB25 connector. Buy a DB25 breakout board from Amazon:
Connect using the standard schematic:
Your GR214V ground will go to DB25 Common pin 18-25
Do not connect the ENABLE on the drive.
Give that a try. It may well not be compatible with the signals on the Acorn header.
Because your drives are 5volt logic.
Glad it's sorted
Glad it's sorted
