Probe on an ATC rack
Posted: Thu Mar 25, 2021 10:28 am
by Toaster
Hey all, check this out, I put a probe on my ATC rack. The probe needs a cable connected to it to work properly, and I modified my M6 macro to protect me from accidentally changing the tool with the cable still attached, this is how it works:
https://photos.app.goo.gl/LB6V635eLTsC1S646
Hopefully this helps someone else out there that. wants to do something similar.
Re: Probe on an ATC rack
Posted: Thu Mar 25, 2021 11:14 am
Nice work! Thanks for sharing what you did and how you accomplished it.
Posted: Thu Mar 25, 2021 1:34 pm
by Toaster
Thanks Marty!
Posted: Thu Mar 25, 2021 9:21 pm
by carboncymbal
Toaster wrote: ↑Thu Mar 25, 2021 10:28 am
This is very cool! I bet with a bit of effort you could expand your idea to include automaticity connecting the wire. For example, you could use a magnetic connector or some other type of low-force plug.
Other spring loaded electrical connectors could be an option as well.
Basically the probe could have a short wire (like yours does) and it could be held on some holder, picked up with a small move before the probe is picked up by the spindle. This could be similar to how you dock your dust hood.
Posted: Thu Mar 25, 2021 10:46 pm
by Toaster
Posted: Fri Mar 26, 2021 2:10 am
by carboncymbal
Ah yes! That would work as well!!
Posted: Fri Mar 26, 2021 12:24 pm
by slodat
I have a
XoomSpeed wireless conversion on my Hallmark ITTP for this exact reason - I plan to have a rack type ATC in the future. It works well.
Posted: Fri Apr 02, 2021 9:48 pm
by mrp192
I also have a probe and I'm in the middle of switching over to an ATC setup. I have been thinking about a better option for the probe cable and I am going to try this.
https://www.aliexpress.com/item/3304994 ... lsrc=aw.ds
Blah Aliexpress
I would love to get a true wireless probe but right now it is not in the budget.
