Acorn controller card question
Re: Acorn controller card question
noel-nogal wrote: Sat Jul 03, 2021 1:43 pm it is fixed now, what i did, on the wizard in homing and traveli changed the automatic homing sequence, and it works i have no idea why that haappen, also the readoouts shows zeros on Z axis when it should show 8.55 on this machine
Home the machine.
Press ALT D
That shows MACHINE position. The DRO's should be all zeros after homing
Press ALT D again, this is your last part position (G54)
noel-nogal
CNC Control System Serial Number: (2669)
Post by noel-nogal »
what i see now is that the WCS #5 (G58) is showing me on the top of the screen, is not on G54 that's why zeros on all axis, i need too change that to G54
noel-nogal
that's it, is working now, i had thhe wrong WCS.
noel-nogal
Hi Marty
I have a cnc router machine equipped with indramat Rexroth drives, HMDO 1.1N-W0012, they comunicate by optic fiber sercos system to computer, do you think this type of drives can be retrofitted with Acorn and cnc12?
thanks
noel-nogal wrote: Fri Jun 17, 2022 10:33 am Hi Marty
thanks
Unlikely But you need to post pictures of the current control cabinet, drives and have you Google searched your drive model numbers to see if you can find a manual? If so, post here.
noel-nogal
thanks Marty
yes i found the drives manual, it mention on chapter 7-5 three mode of operations, sercos interface, field bus interface and parallel/analog interface so looks like there is only +10v analog input, and does not support step and direction, if i am not wrong.
https://www.convertingsystems.com/uploa ... hcs031.pdf
noel-nogal wrote: Fri Jun 17, 2022 10:11 pm thanks Marty
The link you provided does not work for me.
If it drive does not support step and direction it will not work with Acorn
