So all I would be able to do is jog ? No setting or cycle start , feed hold, is that what functions you are talking about ?
Re: Wired MPG for Acorn?
Posted: Wed Apr 07, 2021 10:11 pm
by cad cam man
These are the pendants I am referring to "wired mpg pendant "
Posted: Wed Apr 07, 2021 11:39 pm
by tblough
You could probably make those work with the AllIn1DC or Oak, but not Acorn.
Posted: Thu Apr 08, 2021 12:05 am
The one with the blue knobs "appears" to be the same one Centroid uses on Oak and All in On DC
It would use up a lot of inputs IF it could be made to work.
Buy the wireless MPG and save yourself the trouble. Or if miiney is an issue, get the Contuor Shuttle Express
Posted: Fri Apr 09, 2021 10:50 pm
by lavrgs
Good new on being able to use the Contour shuttle - another + in the Acorn column. I am working to get my current control working with the thought that if I get it working properly the Acorn upgrade should be easier.
Posted: Fri Apr 09, 2021 10:54 pm
lavrgs wrote: ↑Fri Apr 09, 2021 10:50 pm
I was just on you tube and came across the allin1 board but at 14:02 they talk about using the encoder port for lathe mpgs i wonder if this would work for the cheap mpg like I was talking about
