Machine bought new direct from Felder UK without the standard Eding Controller.
Setup:
- Felder Group's Hammer HNC HF Router with air cooled 2.2kw Teknomotor Spindle https://www.felder-group.com/en-us/prod ... 82-p142995
- Leadshine MX4660 driver, Meanwell RSP-320-48 48v PSU and relays all under-slung the router deck
- Router's External connection interface presented as DB25 (I/O) and DB9 (E-Stop)
- Schneider Altivar 320 VFD (Model ATV320U22M2C) mounted in separate steel case with incoming line filter. The VFD is hard wired to Router with extended 2 metre lead
- Both Router and VFD case have their own mains power plugs with earth connection
- All above installed, pre-wired and configured by Felder prior delivery
- VFD parameters set by Felder to min 100Hz (6,000 rpm) max 400Hz (24,000 rpm) and control uses AI1 set for 0-10Vdc
- Control cabinet therefore just houses the Acorn and its PSU, 8 x Relay board and 2 channel E-Stop plus DB25 BoBs and presenting an external DB25 and DB9 to match the Router's external conectors
- Control Cab to router connections: 25 core shielded parallel and 4 core shielded CY cables. Both shields grounded at Control Cab only
1) OEM's VFD to spindle power cable shielded but NOT connected to GND at either end
2) OEM's Internal control cable to VFD not shielded (LAPP Olflex Classic 110 7 core x 0.75mm)
3) Felder has directly tied the Router chassis ground to the onboard 0Vdc COM at control cable connection to VFD COM
4) VFD control cable routed parallel to Spindle Power cable over full chassis length and extension to VFD enclosure with no separation. Test results:
I've attached the VFD installation and Programming manuals. The usual report and the Electrical Layout as provided by Felder in German with my rough translation to follow.
Any ideas?
