I decided to upgrade motor tp clear path and build a next control box. With a clean sheet I fired it up and now can I not get the board to respond to an Estop
What I know:
1) the only connection to this board at present is the Estop. It is a NC switch which is working as verified by the on/off continuity. For demonstration purposes the attached Pic shows a simple wire hook up between ground and ENI 8. Switching between nc and no in wizard simply locks in estop on or off.. no change via the switch. multimeter shows a clear path to com.
2) centroid 4.5 is not giving any error message via the log
3) The voltage to board is at 24V the com to switch and the heart beat looks OK to me.
I have tried to boil this thing down to the basic and eni8 simply does source or sink on eni8. It is certainly something simple but I can not see it.
see attachments. Thanks for any help that can be offered.
back to basics
back to basics
- report_3403DE64EC1B-0814192360_2021-03-08_18-11-38.zip
- report that the same time as pic 1
- (686.33 KiB) Downloaded 82 times
- CNC Control System Serial Number: 0035FF8A1900-10082038
Re: back to basics
Do you have a +24v jumper going to the +24v terminal near the inputs?
Is that red wire going to 24IN or input 8?
I’d suggest pulling up the schematic and double checking that portion of the diagram.
Also, I see an exposed wire hanging right over your acorn. That is a big risk, weather it is 24v or common, electrical contact could fry the entire thing.
Re: back to basics
hi, please update to v4.62 as free support for v4.5 has ended. thanks.
Re: back to basics
Yes , the red goes to input 8
The red wire is twisted to the black wire to simulate the esop connection to show the simplify the connection. I used the mushroom button on the spindle to test but its out view so I simply showed the connection in the picture
Re: back to basics
The system has been updated to 4.62. The problem as stated before remains the same.
Any ideas???
Any ideas???
Re: back to basics
please post a fresh v4.62 report so we can see your settings and help you.
Re: back to basics
in the photo i do not see a 24 VDC positive wire connected to H4 24 vdc IN. circled in red in the image below.
Re: back to basics
Did you see my post?curiousMike wrote: ↑Mon Mar 08, 2021 10:29 pm The system has been updated to 4.62. The problem as stated before remains the same.
Any ideas??
Re: back to basics
take a look at schematic #S14954 it shows the E stop circuit without a bunch of other stuff so its easy to understand.
- S14954-ACORN_rev4_LIMITALL_HOMEALL.pdf
- (152.47 KiB) Downloaded 95 times
Re: back to basics
yep! good call.. thanks for the help!carboncymbal wrote: ↑Mon Mar 08, 2021 10:41 pmDid you see my post?curiousMike wrote: ↑Mon Mar 08, 2021 10:29 pm The system has been updated to 4.62. The problem as stated before remains the same.
Any ideas??
just want everyone on v4.62 and a fresh report before we proceed with tech support, standard procedure.
