Hi there, I need to be able to control my Acorn's outputs.
Look at the acorn_mill_plc.src file starting at line 3211
I need my Acorn to send on it's output W72 = 6 Program Finished when the homing cycle is complete as well as any other program file (.cnc file).
I tried to add "Program_Finished_M = 1" at the end of my .HOM file but that caused an error.
I have an external PLC that is receiving these binary codes (xxxx) and doing different things.
Please help,
PC
need Acorn PLC output trigger in HOM file
- CNC Control System Serial Number: 2650
- report_0C1C570715C2-1107192650_2021-03-05_13-36-54.zip
- (747.1 KiB) Downloaded 89 times
Re: need Acorn PLC output trigger in HOM file
In my .HOM file, the program running is set (the output sends binary 0011 or 3 in decimal) when the homing sequence begins. It does not send binary 0110 or 6 in decimal when the homing sequence is complete.
Hello pmchoudek,
Try adding M94 /10 at the end of your home program.
Looking at your Custom PLC this is what is written.
So for you to get W72 to = 6 you must activate "Program_Done_M_Code" which will be a M94 /10. The PLC will then automaticlly reset this bit and set W72 back to 0 after 25ms due to the Timer Program_FInished_Delay_T.
I suggest checking out our PLC manual that breifly goes over M94 M95 commands in the PLC. Starting on page 68 "Custom M-Codes". If your interested in learning more about PLC programming. Also check out the video series in my Signature for Centroid PLC programming.
Additional information on M-codes can also be found in our Mill or Lathe manuals found on the centroid Website
Program_Done_M_Code IS SV_M94_M95_10; SET TurnClampOn, M11 RST TurnClampOn
;-----Program Finished----;
IF TRUE THEN Program_Finished_Delay_T = 25
IF Program_Done_M_Code THEN (Program_Finished_PD)
IF Program_Finished_PD THEN SET Program_Finished_M, SET Program_Finished_Delay_T
IF Program_Finished_M THEN W72 = 6
IF Program_Finished_Delay_T THEN RST Program_Finished_M, RST Program_Finished_Delay_T, W72 = 0
Centroid PLC Tutorial Videos
All Acorn documentation is here.
viewtopic.php?f=60&t=3397
Introduction to Centroid Macro Programming is here
https://www.centroidcnc.com/centroid_di ... amming.pdf
Thank you for the suggestion! I was a little confused on how and when the binary signals were being sent. It would send the 'program running' signal after every operation it seemed like. Where I was thinking it was only sending that signal when the job file was started... I was not the one who designed the program in the PLC, but thank you for helping me understand.
After testing the m94/10, I found out that it does work to send the 'program finished', but then realized what I described above. So I just kept the M94/10 omitted from my home file. I think my issues were better solved in my external PLC than in the Acorn.
