Mdi 511 parameter missing <G0 not Go>
Markostojic
Post by Markostojic »
Hi
This is my first post. I have next to no experience in electronics and cnc in general but can follow schematics. I have succesfully managed to be able to home my router which has clearpath servos and a c86 board with a rack and pinion on x and y axis with a 5/1 gear reduction on both axis 3411 elm and a 5mm lead ballscrew on z with 3421 eln motor. I was initially able to move the router with mdi commands but am no longer able to as error message 511 parameter missing and i have ran some mm acorn programs hovering over the table, my spindle does not turn on after a couple of tool changes. Thank you in advance for any replies and sorry for dumb questions which i am sure i will have plenty off
Regards marko
report_E415F6F96750-0708203489_2021-02-18_18-17-25.zip
(625.02 KiB) Downloaded 92 times
cnc_smith
Re: Mdi 511 parameter missing
Post by cnc_smith »
Looking at your file for MDI history file your are typing Go (letter o) not G0 (the number zero), that is why the error message 511. Any G or M commands it is always numbers, no letters after the G or M. The big mistake is using the letter o for zero.
Dana
Marko,
Download and read the CNC Mill Operator's Manual. Much of it still applies to your router.
https://www.centroidcnc.com/centroid_di ... -v4.14.pdf
Markostojic
Re: Mdi 511 parameter missing <G0 not Go>
Hi Marty
