Hello,
FYI: I just added backlash comp to my X axis. Went to "PARK" the machine for the night and the "X" axis lost control but did not crash the machine. I turned off X comp under config/motor and Park returned to normal operation.
Rick
4.62 X axis backlash comp turned on - X axis runaway during park
Re: 4.62 X axis backlash comp turned on - X axis runaway during park
Hi Rick,mantis3347 wrote: ↑Tue Feb 16, 2021 1:35 am Hello,
Rick
Explain "the X axis lost control"
We need details about your machine, what type what axis drives/motors...pictures etc. basically everything asked of in this post:
viewtopic.php?f=20&t=383
ALWAYS post a fresh report.
See if you can recreate the issue.
Video clip would be great (upload to YouTube set to private and share a link here)
If the issue is repeatable, a description of how to create it, then it can be taken a look at.
which "park' are you using the one on the VCP or the Park button the in the cnc12 shutdown menu?
and please post a fresh report.zip
