The pawn was causing a totally separate issue to my original issue. It took a long time to discover this though, all those wasted hoursmartyscncgarage wrote: ↑Wed Feb 17, 2021 10:36 am Yes, start a new thread....sounded like you found the issue with the Pawn program but then you didn't???
Z axis has suddenly stopped going forwards <resloved>
- CNC Control System Serial Number: 0035FF8A7F34-0730203594
Re: Z axis has suddenly stopped going forwards (only when running gcode, it goes in both directions when I use the MPG)
All is good now. No more home switch tripping, and the original problem send to have gone in the process. I'm not really keen to try to find the root cause of the original issue, since I am very much behind with everything else. Thanks to everyone that helped with this.
