New Build: SYIL X4 CNC Mill, Clearpath SDSK, C86ACCP & Centroid Acorn
karthick0320
Re: New Build: SYIL X4 CNC Mill, Clearpath SDSK, C86ACCP & Centroid Acorn
Post by karthick0320 »
martyscncgarage wrote: Tue May 18, 2021 3:41 pm How old is your C86ACCP? What revision is on it?
My C86ACCP is more than a month old. I have the REV2.
Markostojic
Post by Markostojic »
I had the same problem and when i unticked drive enable in the wizard on my axis i had no more problems
snortwheeze
CNC Control System Serial Number: 4230
Post by snortwheeze »
carboncymbal wrote: Sat Feb 27, 2021 2:02 pm
martyscncgarage wrote: Fri Feb 19, 2021 11:15 am
Gary Campbell wrote: Fri Feb 19, 2021 10:46 am Please note, that like some others, I am a bit hesitant to use these boards until a proper solution to secure them is in hand.
Would be nice if one of are users proficient with CAD and 3D printing could design and make some brackets for it.
Anyone? Anyone? :D
I'll have you covered! I'm going to be using the C86ACCP will be making a 3d printable bracket for it. I'll also provide the general dimensions of the combination that will be derived from 3D scan and hopefully a C86ACCP solid model.
Clay
Did you have an opportunity to make an stl file for a bracket to hold the C86ACCP securely to the Acorn board?
