Hi, I have a question about configuration of limit switched and using auto squaring. Right now I have my Acorn board setup with each switch configured to a separate input, normally open, and using 'FirstAxisHomeLimitOk', 'SecondAxisHomeLimitOk', 'ThirdAxisHomeLimitOk' and then the slave switch as 'SlaveHomeInput'.
I'm trying to setup AutoSquaring using the wizard and I can't get it to work. Without going into the details of why it won't work yet, I can't help but notice that all the guides for Auto Squaring say to use all three switches wired in parallel to 'HomeAll'. Will auto squaring refuse to work unless you use the exact configuration with 'HomeAll' and 'SlaveHomeInput'?
For reference, the machine is a CNC Router, Avid CNC PRO4848 using the default Pepperl+Fuchs proximity switches (https://www.pepperl-fuchs.com/usa/en/cl ... rodid=3441)
Thanks.
Auto squaring and limit switch configuration
Re: Auto squaring and limit switch configuration
please follow the auto squaring directions to the T if you want to use the Wizard generated auto squaring homing program.
https://www.centroidcnc.com/centroid_di ... _guide.pdf
the stock auto squaring home program is written for use with HomeAll
other methods will work but that up to you to write that home program for other scenarios.
overview quickie video i made at a customers machine i visited recently.
https://photos.app.goo.gl/nv1JY6YruWAWu3HfA
Hi Keith, Thanks for the help. I did end up re-wiring my homing switches to a configuration that uses ‘HomeAll’ and the auto squaring wizard works like a charm now.
great, thanks for reporting back.
