Acorn Inputs/Outputs
- CNC Control System Serial Number: ACORN 3499
I'm trying to do simple logic in my plc program. Whatever the state of input 3 reflects the state of output 8. Also the state of input 4 reflects the state of output 7. I have declared variable names in the input section and did the same with the outputs. I followed the steps in video that is posted in the help section When I compile the program I get the following error attached in the png file. Have not been able to generate a report file yet (which will do tomorrow when I'm at the machine). I'm not trying to do any macros or anything like that just straight inputs=outputs. Kind of stumped at the moment even following the tutorial. I have attached my src file also. Tia
- Z_plc.src
- (228.39 KiB) Downloaded 107 times
Re: Acorn Inputs/Outputs
Hi,
This message from the Compiler is telling you that the label in your PLC logic is not defined (Not a Mem, Output, Input, Word, ect).
It looks like you replaced "OUTPUT7" with "Cltch_Dec_Out" in the PLC but did not give "OUTPUT7" another definition. The easiest way to fix this is to simply Remove the Line "IF M67 THEN (OUTPUT7)" from the PLC. Another way you can fix this is by giving OUTPUT7 a definition for example making it a Mem bit. "OUTPUT7 is MEM327" as an example would resolve this issue as well.
Centroid PLC Tutorial Videos
Note that tokens like "OUT1" and "OUT7" are pre-defined in the PLC language, and always refer to the hardware outputs.
Note also that "OUTPUT1" and "OUTPUT7" are not pre-defined, and do not inherently mean anything. They are only defined if you write a definition for them in your PLC program, using the "IS" keyword. For example, "OUTPUT7 IS OUT7" or "OUTPUT7 IS MEM327".
You should give only one name to each input and output. You should make sure you are only running one block of logic to control any given output.
With Acorn systems, you have the added complication of figuring out whether you want to work within the Wizard, or whether you need to bypass the Wizard and add your desired features directly. The Acorn/Wizard way of doing things is helpful as long as what you need is something Centroid already wrote for you, more or less the way you want it. Otherwise, it tends to put a lot of obstacles in your way (or at least, a lot of clutter you have to work around).
The Acorn Wizard has opened up machine tool configuration and customization to 4400 users that would never have been able to program a PLC program even for simple things like adding a limit switch or a light tower. For the current list of stock drag and drop PLC functions available in the Acorn Wizard see this doc... https://www.centroidcnc.com/centroid_di ... ctions.pdf
For the 1 out of 2000 users that want to and are able to, the Centroid PLC program is completely free and open to modify how ever the user sees fit! The Centroid PLC programming system is very powerful which allows the user to heavily customize the CNC control. We also developed and have made available for free our "PLC Detective" program which is instrumental when creating custom PLC programs.
Centroid PLC programming Resources.
Video Series.
forum thread with quick simple plc programming video
viewtopic.php?p=8871#p8871
PLC detective manual
https://www.centroidcnc.com/downloads/c ... kstart.pdf
PLC programming manual
Video Series.
