E Stop (Resolved)
blksmth
CNC Control System Serial Number: 4063
E Stop (Resolved)
Post by blksmth »
I completed the bench test, then hooked the E stop to the Acorn, it works fine on the Acorn with E stop reset I have a green led on input 8 and when depressed led turns red like Keiths video. But on the cncpc the function is inverted. With E stop depressed the PC shows reset, and when reset it shows tripped. The E stop has N C contacts.
report_E415F6F30A3E-1119204063_2021-02-03_11-40-40.zip
(285.91 KiB) Downloaded 107 times
Re: E Stop
blksmth wrote: Wed Feb 03, 2021 3:47 pm I completed the bench test, then hooked the E stop to the Acorn, it works fine on the Acorn with E stop reset I have a green led on input 8 and when depressed led turns red like Keiths video. But on the cncpc the function is inverted. With E stop depressed the PC shows reset, and when reset it shows tripped. The E stop has N C contacts.
Show screen shot of the Alt i diagnostic screen please.
blksmth
Re: E Stop
Post by blksmth »
The first screen shot is taken with the E stop reset. The second screen shot is with the E stop tripped mashed in. I need to figure how to add screen shot to to this reply.
Re: E Stop
Go full editor and preview.
Click on the attachments tab under the text box. Point it to your files.
blksmth
Re: E Stop
Post by blksmth »
Hope this works
Re: E Stop
Your input is inverted. Go into the Wizard and click on the red LED next to ESTOP input 8
It will change to green.
Right now the control thinks you have a NORMALLY OPEN switch
blksmth
Re: E Stop (resolved)
Post by blksmth »
Thanks its correct now. I thought I looked at that several times but didn't catch it. Roy
