Altaros Turret
- CNC Control System Serial Number: 3639
Altaros Turret
I would like to know if anybody has seen the Altaros Turret. I guess it has a macro for Mach 3 https://www.altaros.cz/en/content/53-au ... urret-head. Would like to know if this will work with Acorn.
Thanks John
Thanks John
Re: Altaros Turret
That looks pretty nice. It appears that as long as you have a free input and a free output, the Acorn should ne able to control it with no problem. The supplied M6 macro looks like it should be easy to convert. It is a delay based sequential changer.
Re: Altaros Turret
Thanks Tom that’s what I thought. How do you go about converting a macro?
Thanks Again John
Thanks Again John
Re: Altaros Turret
That looks pretty interesting. My guess is that the acorn can control it. I may be wrong but I think there are some instructions available on using a sequential changer.
My concern is how do you adjust the proper tool height of each tool or ensure drill bits are vertically centered? I don't see any clues on this and have learned with my turret lathe that adjusting the tool height is a serious concern even if you take a lot of precautions to ensure the turret is machined properly. I've looked at Tormach's Slant Bed turret instructions and Tormach even says that tools may need shimmed.
Re: Altaros Turret
Always good etiquette to provide a link to the documentation or post them here.
Being the nice guy that I am, here they are....
- ATH-MANUAL.pdf
- (1.28 MiB) Downloaded 124 times
- M6Start.txt
- (3.43 KiB) Downloaded 103 times
Re: Altaros Turret
Most good quality turning toolholders have the top shank surface at the cutting height of the insert. If not, those would have to be machined/shimmed to the correct height. The tool blocks have to be shop made for drilling type tools and those could be bored in-place using the lathe in question, or set up with eccentric bushings to provide a small amount of height adjustment.
Re: Altaros Turret
Ok guys I ordered the turret. I have never messed with a macro. I hope I can get some help to get the turret running. What do I do with the macro?
Thanks John
Thanks John
Re: Altaros Turret
When you get it, figure out the exact sequence of events. Post it here.Clausing2020 wrote: ↑Thu Feb 18, 2021 11:13 pm Ok guys I ordered the turret. I have never messed with a macro. I hope I can get some help to get the turret running. What do I do with the macro?
Thanks John
DIY=Do it Yourself, that's not to say someone here can't "help" you.
Centroid can be employed to help make it work. There is a fee. It seems relatively simple
Keep us posted on your progress!
Re: Altaros Turret
Ok thank you Marty I just don’t know what to do with the Macro. I know I can download the mach 3 macro. Then what do I do with it? I just never had to play with the actual macros
Thanks John
Thanks John
Re: Altaros Turret
You'll need to go through the Mach3 macro line-by-line translating the Mach3 commands into the equivalent Centroid macro commands. This document should give you a good start: https://www.centroidcnc.com/centroid_di ... amming.pdf
