Dear all,
I have a confusing problem with jog motion from the CWP-4 pendant using ACORN PRO, v4.14.
It seems confusing to me because ALL the axis are working fine when homing to switch, responding to jog command when using CNC PC keyboard, and X and Z axis are jogging fine from the wireless controller, but not the Y axis. If this is important, Y axis has a paired slave axis N, which I suspect to be a possible problem. However I simply don't know where to start troubleshooting. Has anybody faced this issue?
Thank you in advance!
Problem with CWP-4 wireless pendant <resolved>
Re: Problem with CWP-4 wireless pendant
You need to update to the latest CNC12. Then post a report so we can see what you've got going on in your system.
See this thread for more info: viewtopic.php?f=60&t=1043
- CNC Control System Serial Number: E8EB112ABED0-0426180874
Dear slodat, thanks a lot, eventually updating the CNC12 version to v4.5 resolved the problem!
Best regards!
Best regards!
