Losing Z and X
Re: Losing Z and X
In the video you went to home the machine, was it homing and then it stopped IN THE MIDDLE the travel or did it hit the END of the travel and stop? Which axis was moving when it stopped?
Look at the clear path motors through the opaque white plastic cap. Are they blinking green rapidly or do you have another color and which axis?
JerryLouisMartin
CNC Control System Serial Number: E8EB1128AAC4-0405180824
Re: Losing Z and X
Post by JerryLouisMartin »
Marty,
When I tested the machine it stopped in the middle of the program. on the z axis. All function to include rotation
Both Motors are yellow solid.
Re: Losing Z and X
Here is what a SOLID YELLOW means:
This would seem to indicate that the motors are being DISABLED.
You need to get with your builder or tech to resolve this.
If it were me, I would try the C86ACCP board from CNC4PC.com
IF the 8 pin molex connectors were not cut off the ends of the cables.
Re: Losing Z and X
JerryLouisMartin wrote: Sat Feb 20, 2021 4:13 pm Marty,
The next time this happens IMMEDIATELY create a report, F7 Utilities, F7 Create Report and post it here.
Simply go and create the report.
Re: Losing Z and X
In looking again at your last report/message log:
(4) 02-12-2021 10:44:57 9033 Reset Initiated, Press Reset to Clear
(1) 02-12-2021 10:44:57 407 Z+ limit (#50003) tripped
(1) 02-12-2021 10:44:57 407 X+ limit (#50002) tripped
(4) 02-12-2021 10:45:37 4032 Reset Cleared
(1) 02-12-2021 10:45:43 407 X+ limit (#50002) tripped
(4) 02-12-2021 10:49:50 9033 Reset Initiated, Press Reset to Clear
(4) 02-12-2021 10:49:55 4032 Reset Cleared
(4) 02-12-2021 10:50:38 5038 SPECIFIED SPIN SPEED < MIN SPIN SPEED
(1) 02-12-2021 10:50:52 407 X+ limit (#50002) tripped
(1) 02-12-2021 10:51:54 452 Ethernet Communication Error, CNCPC to controller. See Tech Bulletin 270
There is an X+ limit tripped When you home the machine, watch the sensor and see if it blinks at all when it is trying to home but BEFORE the sensor sees the target.
Can you take and post your INPUT wizard page please? Also can you read the part number on the proximity sensor?
