Bonsoir,
Voilà j’ai reçu ma carte Acorn Centroid et fait un câblage test.
Le Logiciel reconnait bien la carte.
J’ai branché un driver chinois (2H45B) mais ça ne fonctionne pas.
Je n'ai pas trouvé le manuel du driver.
Quel type de driver je dois déclarer dans le logiciel?
Here I receive Acorn Centroid card and I do test wiring.
The Software recognizes the card well.
I plugged in a Chinese driver (2H45B) but it doesn't work.
I do not found the driver manuel.
What type of driver should I declare in the log?
Thank you,
Francis.
Configuration du driver
Re: Configuration du driver
follow hook up schematic for Leadshine DM 856/870/1182/2282
- CNC Control System Serial Number: System ID E415F6F2033A-1211204193
On the wiring diagram The ena + and ena- outputs are not connected.
Does the Acorn card not drive these outputs?
Francis, I see Keith answered your question well.
try it first without the enables, once you get it working without the enable signal, then you can try to use the enable signal.
If I have understand the DB25 is used only for test.
If it is ok, i can use the connector H2 or H3.
Francis.
Francis.
As has been stated before, and as shown on the schematic provided, you need to use the DB25 connector to connect these drives.
We don't have to only use the DB25 for this type of driver.
I just tested it and it works just as well with the DB25 as the H2.
The Acorn board needs 5 volts for it to work.
Next step The Enable.
Francis.
Francis.
In that case, good luck.
