Looks like you have newer steppers. No reason not to use them. I might suggest you set the microstepping on the drive to 2000.
In inches on the machine I just setup, revolutions per inch was about 20.3
Configuration du driver
Re: Configuration du driver
- CNC Control System Serial Number: System ID E415F6F2033A-1211204193
Hello Martys,
I am not moving very fast because I do not have a lot of time and I am also waiting for orders placed for the retrofit. I have received the encoder.
I stripped it off and it is assembled with 2 bearings. So I can do the same assembly you did. I will see the quality over time.
I watched your video on hall effect sensors.
Can you explain their usefulness to me, because unfortunately I do not understand English, I regret not having been more serious at school )
I still have a lot of questions for you, I hope you don't mind.
Thank you
Francis.
Thank you
Francis.
Sensors make for more accurate homing than mechanical switches
You mean they do the machine origin.
Yes. Machine origin is machine home
