Anyone's help would be greatly appreciated!
Here's the issue. I am trying to run this F360 program on my Acorn CNC12 Ver4.14.
I keep getting an "Abnormal Job End" after I load the program and then try to Run it. I have always used F360 with success until now. I have a subscription as well.
Here's what I've done to diagnose it so far so this is all I can tell you.
1: I have made a CAM program using INTERCON and that works fine
2: I have loaded previous Fusion 360 programs from the directory and they run as well.
3: I have gone into F360, post processed the same earlier project, but the NEW copy does not work! I look at them in Notepad and they are identical!
4: I have made a simple CAM in F360 thinking maybe my program was to intense for ACORN. That works.
So here we are. Acorn seems to work but there seems a varying degree of uncertainty around Fusion 360.
I have also reloaded the Centroid post processor from Autodesk.
If anyone can look at or load this program to see what result they get, anything would be appreciated. I know that sounds shady loading a program but Im at my wits end try to get this to work.
Thank you for any input in advance.
Doug
Please Help!! (Resolved)
- John Spoke.nc
- (229.45 KiB) Downloaded 93 times
- report_38D2693C2D16-0727181089_2021-01-12_20-34-37.zip
- (273.32 KiB) Downloaded 104 times
Re: Please Help!!
You're creating a subprogram by using a program number in the rsnge of 9100-9999 without ending it with subprogram return (M99). Read the manual entry for M98.
Re: Please Help!!
ok, thats a start. Honestly I'm new to this so thank you so much. I'll read up on that.
Re: Please Help!!
THAT DID IT!!
So much to learn. Thank you so much.
Really appreciate it.
