1. Which file stores the Machine and Other parameters on selecting Save? report.zip?
2. It seems it is possible to restore all desired parameter values in one go by using a saved (revision controlled) file.
3. Does the controller facilitate accessing the default values for being able to come back to square one after experimenting a lot with the default values (and loosing track of the modifications...
4. What 'ALL' does the report.zip file (created through Utility Menu -F7 sub menu) consist of? Is Machine Parameters is a subset of this file? Would this be already existing on my Acorn? If unzipped, would it be a man readable txt file?
rgds
p.s. - I should have been a bit more investigative before posting this query. I found the following.... so some one could answer only 4th query.
rgds
