Limit and Home switch configuration
terrymcc
CNC Control System Serial Number: waiting on delivery
Re: Limit and Home switch configuration
Post by terrymcc »
martyscncgarage wrote: Tue Jan 12, 2021 11:15 am Sorry. I don't think so.
What motors and drives are you using?
Attached is what I get when I try what you suggest.
Leadshine HBS1108S Drive and 86HBM120H-1000 Motors. What difference would that make?
Also attached report and schematics
Mill_Turn_Power_2A.pdf
(104.15 KiB) Downloaded 89 times
Mill_Turn_Main_2A.pdf
(185.67 KiB) Downloaded 115 times
report_0035FF624033-1118204010_2021-01-12_11-14-09.zip
(601.27 KiB) Downloaded 97 times
Like the software says. You can't mix HomeLimit with Limit All
I assume you have a Lathe installation and Mill Installation of the software?
I would imagine you are hitting the limitations of a number of inputs?
I wonder when you do the manual change from lathe to mill if you couldn't use some relays to swap inputs for you.
(thinking out loud)
please take another look at my post and look closely.:-)
terrymcc wrote: Tue Jan 12, 2021 1:20 pm Attached is what I get when I try what you suggest.
You have the wrong input setting for Input 1. Use "ThirdAxisHomeOk". Not the "limit" version.
terrymcc
Post by terrymcc »
That is how I have been running it. But, when you do that, it will not limit the Z+ travel and can allow a crash.
The issue is I want to Home Z+ but I also want to limit it. All the other limit switches are combined into a limit input.
terrymcc wrote: Tue Jan 12, 2021 6:17 pm That is how I have been running it. But, when you do that, it will not limit the Z+ travel and can allow a crash.
If you configure the soft limits this should not be an issue unless your machine loses steps.
You will have to come up with another alternative or add a second switch to for limit.
terrymcc
Post by terrymcc »
martyscncgarage wrote: Tue Jan 12, 2021 7:23 pm
Thanks Marty. I think it will be OK. The drives are hybrid servos so they shouldn't loose steps and if they do, they will generate a fault which will shut down the machine.
terrymcc wrote: Tue Jan 12, 2021 8:11 pm
Then I would not really have any hesitation on relying on the HOMEALL function. I have used it ALOT with closed loop hybrid servo machines.
