Hello I've recently converted an OEM Avid CNC NEMA 23 controller over to Centroid Acorn (Mach 4... Why is it even sold?) and everything works rather smoothly (100khz seems to work fine with the Leadshine stepper drivers).
However, up until now I've always used LinuxCNC and did all of my tool height offsets manually so I'm not understanding everything perfectly.
I work with wood that I flatten in a planer before CNC and the thicknesses vary some.
Therefore, since my work requires somewhat consistent results I used the spoil board to touch off (IE offset it by how thick the stock is supposed to be), to set tools, and so forth.
Since I use an ER collet system I have no tool holders and must setup everything manually every tool change.
Do I insert my longest tool first, touch off with a conductive or mechanical switch, and then set WCS however I want?
Most examples use two tool setters or a movable switch--but I'm hoping to use a single stationary one, and set my work coordinates manually.
I realize I will need to set an offset of some sort so I only have to enter in stock thickness into WCS and there's some details that I'm not clearly seeing.
My username info mentions how I use CNC12 and a few other details--it's just a simple 3 axis router but I'm from the dark ages on some things as you can see.
Tool touch off from a single point.
Re: Tool touch off from a single point.
Look at the ProbeApp and this post Guide on how to measure Tool Heights and set WCS Z0 on a Router or Mill with none-fixed Tool Holders most efficiently. It will give you all the options you want.KJNC wrote: ↑Sun Jan 03, 2021 9:20 pm Hello I've recently converted an OEM Avid CNC NEMA 23 controller over to Centroid Acorn (Mach 4... Why is it even sold?) and everything works rather smoothly (100khz seems to work fine with the Leadshine stepper drivers).
The Single Tool Setter Method allows you to either measure the tools with the tool setter on top of the stock or as you want to do, at a fixed location on the spoil board and you enter the stock thickness as an offset. You can use the M6 Tool Change macro that comes with the ProbeApp that will launch the ProbeApp-ToolSetter at every tool change and will measure the tool height offset of the new tool before the job continues.
The ProbeApp also supports the Avid Touch plate that will allow you to also set WCS X0 Y0 in addition to measuring tool height offsets.
-swissi
While Swissi makes a great probe app,
Go to YouTube and watch Centroid CNC Mill Training video. While its more complex than for a router, the part setup concept is the same.
I think its worth a 1 hr. watch.
- CNC Control System Serial Number: 0035FF8A2978-1009203821-MPU12-System
Thank you Swissi and Marty for the responses.
Although the Probe App looks great I've found that a basic tool length offset works on LinuxCNC--so I think after watching some videos I'll likely find the basic method that Centroid Mill uses (I do strongly think a cheap 3d taster with Probe App might help me down the road).
I've gone through the manual some and it's great seeing high caliber documentation.
I suppose the one thing I might have not seen is an explanation for what the acceleration time means in the Wizard Setup (I don't see docs for this--but could be totally wrong). Yesterday I skimmed through Marty's video of setting up a single X axis on a bench and wanted to know what the Accel meant--as I do 3d work and wanted to start some benchmarks.
I don't know which is preferred but I attached a screenshot from the video and circled the setting--the machine is accelerating fast enough that I suspect this isn't IPS^2 format and I'd like to tune some settings for 3d production work.
Accel/Decel is the time in seconds that the motor ramps up and slows down.
Too fast and the machine can be jerky and abrupt...
- MPU11 & GPIO4D -w/ 3rd Party Drives: Yes
7804732B977B-0624192192 - Location: Boston, MA
As Marty said. Number of seconds to reach max Rate. Smaller numbers = faster acceleration, jerkier moves, possible motor over-current faults.
