See chapter 4 of the Mill Operator's manual - section 4.2 shows how to set up WCS. You can download the manual on link https://www.centroidcnc.com/centroid_di ... loads.html then scroll down to the All-in-One section in lime green and look for "CNC12 Mill Operators Manual"routebot wrote: ↑Thu Jan 07, 2021 12:52 pmI need to look into this. If I can save a WCS that would be perfect. CNC12 is new to me and I have a lot to learn!!Nigelo wrote: ↑Sat Jan 02, 2021 9:07 am Unless I am missing something and you have used all available WCS depending on your licensing, why not allocate one (e.g. WCS6) just for the jig. Then you are ready to go as and when required but still retaining the flexibility of the other WCS settings for other work. Advantage is no programing required
WCS zero X and Y macro
E415F6F70BC3-0318203049
Re: WCS zero X and Y macro
Hope this helps
Nigel
Nigel
