As a side note, the X doesn't creep until initial movement. If I powered it up and left it, no problem. If I move the Z axis first the X would creep a little but not as bad as it does after moving the X.
I can order another filter but wanted to be sure I wasn't overlooking something else. They're about an inch apart; should that matter? Magnetic interference from something? The Z filter is right there so why affect one and not the other?
Maybe just a bad unit?
Hardinge with an Accuslide - build thread here viewtopic.php?f=60&t=5043&hilit=hardinge
Motors - DMM DST-640 - https://store.dmm-tech.com/products/dst ... ervo-motor
specs - http://www.dmm-tech.com/Files/ACSMTR-G1-1002A18A.pdf
Drivers - DMM DYN4 - https://store.dmm-tech.com/products/dyn ... ervo-drive
manual here - http://www.dmm-tech.com/Files/DYN4MS-ZM7-A10A.pdf - wiring diagram page 22
Wired as shown except the E-stop. I wired that to the Acorn and put a toggle switch in it's place to the drivers.
All driver to motor wires are DMM supplied and the one that goes to the Acorn.
Acorn Board - drives wired to terminals NOT db25
misc electrical supply hardware per DMM manual
breaker - Eaton FAZ-C20-3-NA - https://www.automationdirect.com/adc/sh ... z-c20-3-na
contactor - Fuji Electric - SC-E03G-24VDC - https://www.automationdirect.com/adc/sh ... e03g-24vdc
main noise filter - Schaffner EMC Inc. / FN2030-6-06 - https://www.digikey.com/en/products/det ... sAIQBdAXyA
logic noise filter - Schaffner EMC Inc. / FN2030-1-06 - https://www.digikey.com/en/products/det ... yBsIAugL5A
There's still some wire management to do but here's where it is now.
Control cabinet
Power cabinet
REPORT
VIDEO - I move the Z axis 1" via the MDI and you can see the X axis motor jog just a tiny bit.
https://youtu.be/73VwYOKaqlY
