I have a Centroid cnc router for woodwork. I’m evaluating the best and easiest way to make large and small signs- up to 8 feet long by 3 feet wide. I also would like to make some 2.5 or 3D carvings. What files transfer into cnc12 or what have others experienced?
Learning curve seemS long for some software.
Thanks!
Software options for signs
Re: Software options for signs
I'd recommend you have a look at Vcarve Pro, it has a rather simple learning curve and will do everything you need. As far as "what files transfer into cnc12"? None will until you run your drawing through the proper Centroid post processor in whatever software you choose. All the Vectric software programs offer a Centroid PP so you can run it on your Acorn powered router right out of the gate. Just be sure whatever software you do decide to use does have a centroid PP because you don't want to have to write you own.
I'll echo what Shawn suggests. The software from Vectric is what most of the router guys are using.ShawnM wrote: ↑Tue Dec 01, 2020 10:57 pm I'd recommend you have a look at Vcarve Pro, it has a rather simple learning curve and will do everything you need. As far as "what files transfer into cnc12"? None will until you run your drawing through the proper Centroid post processor in whatever software you choose. All the Vectric software programs offer a Centroid PP so you can run it on your Acorn powered router right out of the gate. Just be sure whatever software you do decide to use does have a centroid PP because you don't want to have to write you own.
I agree that VCarve is a great piece of software. I use Aspire and have always been amazed at what you can do with it. Aspire and Vcarve are built on the same framework. Here is a Christmas gift I made with my daughter. Sorry the photography is not the best.
We forgot to mention the best opart, you can download and try any of Vectric's software for free. They are fully functioning versions of their software except you can't generate the g code for cutting. You can import dwg and dxf files, draw within the program (I find this cumbersome and still draw in AutoCAD and import my drawings to Vcarve Pro), create tool paths and everything else to see if you like it. You just can't create g code with the demo versions. Give it a try and see if you like it.
Unless you are certain you need the additional features Aspire offers, I recommend not buying Aspire and opting for V Carve Pro. When it’s time to pay for an upgrade the Aspire major version update cost me $400 last year. V Carve Pro version updates are half that or so.
With that noted, I use Vectric for all of my 2D drawing for my router, laser, plasma, etc. Great software for 2D work.
Hello,
A little more about Vectric products:
https://www.vectric.com/upgrade
https://www.vectric.com/free-trial
There are also many great videos online.
If you haven't yet, I recommend you get a copy of ProbeApp from Swissi. A great feature add-on.
E415F6F70BC3-0318203049
Another feature of Vectric's current pricing model is that you only pay the difference between their different products if you subsequently decide you need the more expensive one. I've recently done exactly that upgrading Vcarve Pro to Aspire for just the cost difference. The best feature, unlike many alternatives is that you are buying a perpetual license
Our very own Gary Campbell (aka Mr Gecko ) is mentioned in Vectric's credits so it can't be that bad can it!!
Hope this helps
Nigel
Hope this helps
Nigel
