Guys I am trying to run a simple 5kb size file on my lathe. I don't have the lathe pro license. When I hit run it says upgrade to Lathe Pro and will not let me run it. The NC file for the front part of the part is 4kb and it lets me run it. Any ideas why it won't let me run a 5kb file? I attached it so you can look at the code. Any ideas?
Trying to run file?? (Resolved)
- CNC Control System Serial Number: 0035FF8FEB5F-0708203490
- Top Rear.cnc
- (4.41 KiB) Downloaded 143 times
Re: Trying to run file??
what is the exact error message on the screen? post a photo
Isn't constant surface speed (G96) an extra-cost feature (requiring Pro license or higher)?
Correct Marc:
https://www.centroidcnc.com/centroid_di ... oller.html
Can he comment out the G96 line and test?
ALWAYS Post a fresh report when asking for support. Tells us how your machine is configured and lets us look at the Log files.vw_chuck wrote: ↑Fri Nov 27, 2020 4:40 pm Guys I am trying to run a simple 5kb size file on my lathe. I don't have the lathe pro license. When I hit run it says upgrade to Lathe Pro and will not let me run it. The NC file for the front part of the part is 4kb and it lets me run it. Any ideas why it won't let me run a 5kb file? I attached it so you can look at the code. Any ideas?
You also do not tell us how your machine is configured. We can't "SEE" what you "SEE"
Spindle Encoder?
Follow this post when asking for support. We need to see the BIG picture when trying to help instead of guessing what you have.
Yes I turned off constant surface speed in the PP and it ran fine. I did not know CSS was a pro feature.
Thanks for the help.
