I recently picked up a Hardinge AHC that's been fitted with an Accuslide. The parameters were lost when the batteries died, the spindle encoder is bad and the VFD is DOA. Good candidate for a retrofit .
These pictures are at the shop where I got it. My quarters are too cramped to get a good full on shot. Some parts have already showed up so hopefully progress will be quick.
Hardinge AHC Accuslide Acorn Conversion
Re: Harding AHC Accuslide Acorn Conversion
Good project! I'm wrapping up a Hardinge Accuslide conversion and I'm very pleased with how it's turning out.
Keep us posted on your progress!
Sell the old control parts on ebay to help offset your costs.
Re: Hardinge AHC Accuslide Acorn Conversion
I have an Accuslide lathe I'm converting to Acorn with DMM servos.
Thanks guys, good to know I'm not alone with this project
I plan to list the unused items. A few bucks never hurts.
Got the acorn up and ran through the initial setup. Also the motors/drives and did the initial tune on them also.
I got the computer mount moved back to give me a little more room to move.
Box cleaned out.
New face plate made and mounted. There will be another over this one for the monitor. I plan to mount the drives to the back of this plate.
Box cleaned out.
Looking good so far. Thanks for the build pictures!
A little more progress.
Drives mounted
Monitor mounted to faceplate and then mounted to the box
Made a small bracket to hold the NUK and USB ports - trying not to penetrate the outer shell if I can avoid it.
Drives mounted
Consider a USB bulkhead connector for your cabinet so you have external access to the USB ports.
Can be found on Amazon
I actually have one that I never installed on my Hurco. Its a cheapie ebay item but I actually like this one from DigiKey a little better.
https://www.digikey.com/en/products/det ... 0gEALw_wcB
