Inches to mm
khancnc
CNC Control System Serial Number: 0035FF8A13B8-0729203580
Inches to mm
Post by khancnc »
Hi everyone
If my lathe's turns ratio, tool offsets and and all other parameters is setup in Inches, and now i want to switch it to mm and do some machining in metric size, do i have to redo all my setting again in metric (mm) again ? or will it just run accurate with the same setting.
Thanks everyone in advange
Farrel
Re: Inches to mm
f1 setup, f3 config, type in password (137), F1 control. toggle DRO display and Machine units to Millimetres, F10 save
Re: Inches to mm
To expand upon Keith's advice: when you change Machine Units on the Control Configuration screen, CNC12 will convert all of your configuration and parameter values from one system of units to the other.
Alternately, you can just make sure there is a G21 code at the beginning of the metric CNC program, and run it without changing setups. In that case you would still do your part setup and tool measurements in inches, and you would see inches on the DRO, but the millimeter dimensions in the G code would cut correctly.
khancnc
Re: Inches to mm
Post by khancnc »
Thanks guys, just to sum it which ever way i go either G 21 at the very beinging of the program or change the machine units to mm i will be good with sizes because acorn cnc12 will take care of it ?
Thanks again
Farrel
