*** Acorn CNC12 v4.59 Public BETA rev6 is now available for testing ***
Acorn CNC12 v4.59 Public BETA rev6 is now available for testing!
Please report back your findings, questions and suggestions here on this thread (and not anywhere else on the forum please.:-)
find out about Acorn CNC12 v4.59 BETA rev6 in this document.
https://www.centroidcnc.com/centroid_di ... _notes.pdf
Acorn CNC12 v4.59 BETA rev6 Installation Video
Download CNC12 Acorn CNC12 v4.59 Beta rev6 installation zip file...
www.centroidcnc.com/centroid_diy/downlo ... A_rev6.zip
Acorn v4.6 draft schematic set.
https://fil.email/kVB74W7B
tkbot47
CNC Control System Serial Number: haven't installed CNC12 yet
Re: Acorn CNC12 v4.59 Public BETA rev6 is now available for testing
Post by tkbot47 »
Will the router version support a 4th rotary axis ?
tkbot47 wrote: Fri Nov 20, 2020 11:37 pm Will the router version support a 4th rotary axis ?
Yes. It will drive a 4th axis and work provided your G code is written for a 4th axis.
Re: *** Acorn CNC12 v4.59 Public BETA rev6 is now available for testing ***
The Acorn CNC12 router version requires a router Pro license to fully support axis pairing or 4th axis rotary simultaneous moves.
Router Version has same CNC feature set as Mill Version when it comes to the three levels, Free, Pro and Dig bundle.
For those users that have been using the Mill version on a Router and would like to start using the new Router version of Acorn CNC12...If you have an existing Mill Pro License for a particular Acorn you can purchase a Router Pro License at 1/2 price for that same Acorn. (this will be limited time offer)
If you are actively beta testing and sending in results and reports I'll supply a Router Pro License file for your efforts (limited time offer, only during the public beta test period)
gerald martin
Post by gerald martin »
Looking very good, Keith!
Question about this from the install guide:
"Limitations to 4.59 beta rev6 - G64 Smoothing is not compatible with PWM output. Do not use the G code smoothing feature and PWM
Output at the same time."
Is this a permanent limitation or something that will eventually be solved? My machine runs so much more smoothly with g code smoothing on...
Gerald
Sword
Post by Sword »
Gerald,
This is a good question and is one that as a beta tester, I have posed, as I too utilize smoothing on my production table router (SB-PRS-Acorn). I've mainly been testing PWM for laser use and during that time, just on a benchtop machine that doesn't need much in the way of smoothing settings for the most part, but when I swap the laser to the SB, I might be wanting that smoothing ability. It's yet to be tested for me and it may be just fine for small slower feedrate laser files to be run without smoothing (G64 OFF).
There's one other part to that statement though that Keith may want to clarify. There's a PWM parameter (I won't go into it here now) that varies the PWM output based on feedrate and corners (accel/decel), and as I understand it (from beta testing), that part is what can not be applied alongside smoothing. I also believe it's basically only for laser applications to aid in over burning corners.
That said, there may be some clarification needed for those using PWM spindles, because they may want some smoothing applied.
I'll let Keith respond/explain further...
zz0122
Post by zz0122 »
Could somebody explain it to me what is the main difference between Router version and Mill version, please?
I thought what router can do is the same with what mill can do
TIA
RogDC
Post by RogDC »
Are there any limitations on the 4.59 v6 Beta from my Mill Pro license to test on my router, or will it work comparably?
RogDC wrote: Sun Nov 22, 2020 5:07 pm Are there any limitations on the 4.59 v6 Beta from my Mill Pro license to test on my router, or will it work comparably?
Mill License works with Mill Software. (not the router software, router has its own license file)
zz0122 wrote: Sat Nov 21, 2020 11:22 pm Could somebody explain it to me what is the main difference between Router version and Mill version, please?
TIA
did ya read the notes document?
