ColletOpenClose vs. OpenChuck Outputs
roundel325
Post by roundel325 »
I'm trying to setup a pneumatic collet closer on a lathe. I just need to toggle a single solenoid to open/close it and there are no open/closed sensors for feedback.
I see "ColletOpenClose" output in the wizard but I can't find anything about it in the CNC12 or VCP documentation. Is there a macro associated with this?
I also see "OpenChuck" and "CloseChuck" output assignments, but they have timeouts and faults built in so I'm not sure they are right for my application (single relay output toggling a single solenoid).
Any guidance is appreciated.
Thanks!
Re: ColletOpenClose vs. OpenChuck Outputs
It should be described in this document:
However, ColletOpenClose does not appear to be there. Perhaps someone from Centroid could provide an update.
all acorn documentation is here..
roundel325
Thank you for the tips. I see the "TurnClampOn" output has been removed from the wizard and "ColletOpenClose" has been added but is not documented. Does anyone know if this was just a name change or are they different functions? When I assign an output to "ColletOpenClose" M10 and M11 don't toggle it.
Thanks.
Roundel325
You are correct on the ColletOpenClose. No documentation. It may have recently gotten added as a possible output but not documented yet.
I am currently using open and close chuck. But I also have a foot pedal. I have requested a footpedal input. One that will allow the user to toggle the output on and off to open and close chuck/collet BUT not allow the user to accidentally open the the jaws with the spindle on.
It's on Centroid's list of things to do.
see attached.
Acorn Lathe Chuck and Collet Functionality v4.59 beta rev6.pdf
(278.9 KiB) Downloaded 11 times
roundel325
Thanks Keith! My lathe uses a Dunham collet closer so this information is exactly what I need.
roundel325 wrote: Mon Nov 23, 2020 11:11 am Thanks Keith! My lathe uses a Dunham collet closer so this information is exactly what I need.
Let us know if you give the current Beta a try and if it resolves you problem.
