Hey Swissi,
I have been using probe app v2 and it has been running great so far. One question for you though, is it possible to change the default location on the screen for the pop-up window? I am using a 720p screen and even though I know I'm supposed to be using a 1080p screen everything on the cnc12 side has worked flawlessly. The probe app pop up window defaults to about half of the window off of the bottom of my screen. I can reposition it manually but this gets a little tiresome. Hopefully there is an easy change I can make for default screen location? Any help or insight would be greatly appreciated!
ProbeApp V2: The ultimate solution for Tool Height Offsets
Re: ProbeApp V2: The ultimate solution for Tool Height Offsets
Just press the "Configuration" button on the main screen of the ProbeApp. Move the configuration window to the default screen position you want and then press the Button "Get current Position from this Window". Done.ridekp wrote: ↑Wed May 05, 2021 12:54 pm Hey Swissi,
-swissi
Welp, can't believe I missed that but it worked perfectly. Thanks!!
Thank you.
The Best CNC Machining and Milling Services (CNC Service)https://cncmachinebuy.com/the-best-cnc- ... c-service/
I'm sold. How do I buy, and how much?!
E415F6F70BC3-0318203049
Send an email to Swissi as per his post above. Usually donate ware where you donate what it's worth to you. Really can't get fairer than that
Hope this helps
Nigel
Nigel
