Page 5 of 6
Re: ProbeApp V2: The ultimate solution for Tool Height Offsets
Posted: Wed Feb 17, 2021 11:04 am
by ChrisAttebery
Great minds think alike. I marked my probe to line up with the spindle too.
Posted: Sun Feb 21, 2021 2:32 am
by NovaStar
Cost of this App ??
Posted: Sun Feb 21, 2021 9:04 am
by Upnorth
Cost of the app is whatever it's worth to you. There is no fixed price you just pay the price you think is fair. I highly recommend this app.
Posted: Sat Feb 27, 2021 7:35 pm
by mobilemcclintic
Swissi,
I'm having trouble getting z to set to 0 correctly on a corner plate. It I'm not sure where I'm going wrong. If after probing xyz, it goes to x0y0 great. If I tell it to go to Z0 it goes approximately 1/4" or 6 mm lower than the thickness of the corner plate. Any ideas?
Posted: Sat Feb 27, 2021 8:09 pm
by mobilemcclintic
Sorted, my distance/turn was off on my z-axis. I knew it was something simple.
Posted: Mon Mar 15, 2021 7:15 am
by knastenrad
Is there any option to probe 2 holes/bosses and use the centerline to update CSR?
Posted: Mon Mar 15, 2021 11:18 pm
by swissi
knastenrad wrote: ↑Mon Mar 15, 2021 7:15 am
The current version does not have this option. I do have some ideas of an interactive probing cycle generator that will allow to stack multiple probing moves together to make such options possible. No promises made and definitely no release date yet
-swissi
Posted: Tue Mar 16, 2021 6:53 pm
by knastenrad
great. keep up the good work!
Posted: Sat May 01, 2021 11:54 pm
by mrp192
HEY!!!
For face mills, Is there a way to offset the tool setter? When it touches off the height of the face mill is it hitting the center and not the cutting tip.
Posted: Mon May 03, 2021 10:11 am
by swissi
mrp192 wrote: ↑Sat May 01, 2021 11:54 pm
HEY!!!
In ProbeApp v2.04 you can mark a tool in the Tool Offset Library of the "ProbeApp - Tool Offsetter" that needs special attention for touch off:
In the ProbeApp - ToolOffsetter configuration page you can configure if the cycle should offset the tool by the size of the tool radius and in which direction the offset should occur:
The probing cycle will still stop above the Tool Touch Off device so you can make sure the tool is placed properly for touch off before you press Cycle Start to continue. Some tools like a Fly Cutter still need operator attention to position the tool properly even after the tool radius offset has occurred.
-swissi
