Page 4 of 6
Re: ProbeApp V2: The ultimate solution for Tool Height Offsets
Posted: Sat Jan 30, 2021 5:28 pm
by mrp192
Does the CNC12 4.6 affect probeapp 2?
Posted: Sat Jan 30, 2021 6:43 pm
by swissi
mrp192 wrote: ↑Sat Jan 30, 2021 5:28 pm
ProbeApp v2 works with CNC12 4.6 Mill and Router.
If you are running the Router version and want the VCP button "Auto Z to PLATE" to launch the ProbeApp-ToolSetter, copy this mfunc44.mac file to your c:\cncm folder:
-swissi
Posted: Tue Feb 02, 2021 2:51 pm
by Juda
Good morning.
Swissi just bought a KP-3 probe to be able to make some measurements on a milling machine with acorn 12 software.
I already managed to see some videos on how to configure the KP-3 probe butI need to measure several holes at the same time and in the three axesX, Y, Z could you support me how I can do this in one step.
And also if you can support me to download filesdxf to acorn 12 programming since I could not dolet it read the dxf files.
Regards and I expect your comments.
Vincent
Posted: Tue Feb 02, 2021 4:32 pm
by swissi
Juda wrote: ↑Tue Feb 02, 2021 2:51 pm
Good morning.
Vincent
Based on your questions I have to assume that you do not know much about CNC machining and how CNC machines work. I highly recommend you watch some CNC training videos first. There are plenty for free on the Internet. NYC/CNC has some great videos
here.
-swissi
Posted: Tue Feb 02, 2021 5:06 pm
by Juda
Hello Swissi. okay. I will review them. .
But first, I would like to tell you that I retrofitted a conventional milling machine with hybrid servo motors and the acorn12 controller.
For 4 axes, at the moment I already have the equipment configurations, it is running well, from the beginning to the home, I was watching all this through your videos and the machine is calibrated to be able to make some measurements with the probe,
What I have not found in videos is how to program the probe and how to make it calibrate several perforations in a straight line.
If you need more information about the machine, tell me what it is what you need to know so you can help me.
regards
Vincent
Posted: Mon Feb 08, 2021 5:01 pm
by ChrisAttebery
I'd like to make one suggestion. In the offset library manager could you add a way to input the manual offset (like say x+ 1.000")? So if I have a 3" face mill I enter X+1.500" and the probe routine moves from the tool change position X+1.500" then measures the tool. I don't have a lot of tools that need to be offset, but I think it would be handy.
Posted: Tue Feb 09, 2021 12:34 pm
by swissi
ChrisAttebery wrote: ↑Mon Feb 08, 2021 5:01 pm
As you say, oversized tools that need an offset to be touched off on a tool setter are usually not the norm and maintaining a possible offset field for 200 tools would be overkill. What the new upcoming version 3 will have are additional configuration settings where you can choose if you would like to position the oversized tools with a Tool-Radius-Offset and in which direction (X+, X-, Y+ or Y-) the offset should be.
I think that's a great compromise to your suggestion and will do what you need, right?
-swissi
Posted: Tue Feb 09, 2021 1:07 pm
by ChrisAttebery
swissi wrote: ↑Tue Feb 09, 2021 12:34 pm
-swissi
That's exactly what I'd like. Actually it's more elegant.
Posted: Tue Feb 16, 2021 1:09 am
by ChrisAttebery
BTW: I finally received my Renishaw MP-3 today. I tried locating a corner in 3D, probing a bore, finding an angle, etc. You really did a nice job with the routines.
Posted: Wed Feb 17, 2021 8:30 am
by Muzzer
You really need a DTI with very low preload to set up the runout of the probe accurately. It needs to operate with less force than the probe tip takes to move.
I also use the probe at the same spindle orientation to give a slightly more consistent behaviour.
The probe was one of the best investments I made for my machine. It transformed my accuracy!
