ProbeApp V2: The ultimate solution for Tool Height Offsets
ridekp
Re: ProbeApp V2: The ultimate solution for Tool Height Offsets
Post by ridekp »
Hey Swissi,
I have been using probe app v2 and it has been running great so far. One question for you though, is it possible to change the default location on the screen for the pop-up window? I am using a 720p screen and even though I know I'm supposed to be using a 1080p screen everything on the cnc12 side has worked flawlessly. The probe app pop up window defaults to about half of the window off of the bottom of my screen. I can reposition it manually but this gets a little tiresome. Hopefully there is an easy change I can make for default screen location? Any help or insight would be greatly appreciated!
swissi
Post by swissi »
ridekp wrote: Wed May 05, 2021 12:54 pm Hey Swissi,
Just press the "Configuration" button on the main screen of the ProbeApp. Move the configuration window to the default screen position you want and then press the Button "Get current Position from this Window". Done.
-swissi
ridekp
Post by ridekp »
Welp, can't believe I missed that but it worked perfectly. Thanks!!
cncbuy
Post by cncbuy »
Thank you.
The Best CNC Machining and Milling Services (CNC Service)https://cncmachinebuy.com/the-best-cnc- ... c-service/
TaylorPilot
Post by TaylorPilot »
I'm sold. How do I buy, and how much?!
Nigelo
E415F6F70BC3-0318203049
98F07B91FC6B-0123236802
Post by Nigelo »
Send an email to Swissi as per his post above. Usually donate ware where you donate what it's worth to you. Really can't get fairer than that
Hope this helps
Nigel
