Spindle Encoder cannot be set to "No"
gperezm
CNC Control System Serial Number: 40BD32E4990B-0810181125
Post by gperezm »
Hello when I am configuring in Wizard, the Spindle Setup is always in the option "Yes" and although I change it to "NO" and save the change, when I read the configuration again it is in "Yes". I need this because I want to work with this option from my program. It is worth mentioning that I have an Optimum BF20L Milling Machine with Variator. which in turn has output for CNC. I bought an Acorn card and CNC12 Pro milling software and built my own CNC server.
Could you help me with this problem? Thanks in advance.
Dave_C
Re: Spindle Encoder cannot be set to "No"
Post by Dave_C »
Just a thought here:
Check and make sure the Rigid Tap option is not" on". If it is, I think the encoder option will always be yes.
Dave C.
gperezm
Post by gperezm »
Thanks Dave for your support.
The option "Rigit Tapping" was on and disable it, then change the option from "Spindle Encorder" that was on Yes to No and then save both changes.
When I reopen Spindle Setup, the "Spindle Encoder" option is set to Yes, it's crazy.
Do you have any other suggestions?
gperezm wrote: Fri Nov 27, 2020 1:38 am Thanks Dave for your support.
Yes,
You NEED to post a fresh report when you ask for support. It tells us how you have the machine configured.(F7 Utilities, F7 Create Report)
Have you done ALL configuration via the Wizard?
