Text alerts?
- CNC Control System Serial Number: 0035FF8FEB5F-0708203490
Text alerts?
Is there any way the acorn program could send out a test alert for a tool change? This would be really helpful when I am running a part and I am on the other side of the garage and forget that I am running a part...
- CNC Control System Serial Number: noneC120192
Re: Text alerts?
Well, I don't know any way to configure text msgs, but you could set up a tower signal light to blink, say Amber, when your machine is waiting on a tool change. You should be able to see that from across the garage. Here's an example of one, but there are many more. Just a suggestion:
Re: Text alerts?
Oh that's a good idea. Thanks
Re: Text alerts?
You can also purchase them with a buzzer and add:
"M6#". ;turn on buzzer
G4 P2. ; pause 2 second
"M8#" ;turn off buzzer
To your M6 macro just before the text prompt.
* where "#" is the output that is controlling the buzzer
- CNC Control System Serial Number: 38D2694DE4D2-0423180849
Re: Text alerts?
If you want a text alert, you could use an Arduino. As above, program a relay output and it can be used by the Arduino to send the alert.
https://create.arduino.cc/projecthub/Ma ... ion-a38ae9
