The problem with Chinese hardware is that there is very little documentation.dmbgo wrote: ↑Thu Jan 27, 2022 7:15 pm I probably didn't connect the alarm, even though it is a nice addition to a cnc system. There is no reason why you cant use it if you want to.
The system needs some form of electrical connectivity, so that the servo driver knows unambiguously when it receives a step or direction signal from the controller. I think that the 24v and Gnd on the controller and the servo drive need to be linked for this reason.
It would be nice to have a schematic diagram of the connection between the servo motor driver and the controller.
What connector did you use to connect each pin of the motor driver wiring?
