Stepperonline CL86Y motor wiring error
Posted: Sun Aug 23, 2020 12:12 pm
by Marik
Hey Folks,
Just wanted to share the color code error in the manual for the Stepperonline CL86Y. Finally, got to changing the NEMA34 steppers on my Hardinge HC/Omni Turn slide with Acorn board with closed loop steppers with CL86Y drivers. The main problem for changing was the threading with regular steppers was inconsistent and kept ruining parts. I was following color code printed in the manual for the motor and the system was totally confused, throwing drive errors. After measuring it and few times trying/changing polarity the correct color code is A+ Green, A- White, B+ Black, B- Blue for CW direction. The encoder wiring is fine. The threading now is perfect and very consistent.
Hope this is of help for someone.
Best, M
