Speed setting on vfd not working
- CNC Control System Serial Number: 0C1C57072225-0107202806
Re: Speed setting on vfd not working
Looking at the OMRON webpage, it looks like the encoder you have is an open-collector version. The acorn requires a quadrature version, i.e. +A,-A,+B,-B,+Z,-Z. Investigate this closer but I think this might be your problem. Don't ask why it works when turned by hand without motor running, some thinks are not for us lay people to know. LOL
Also, I would strongly suggest you use a shielded pair cable from Acorn 0-10 to vfd with shield grounded at the acorn end at the 0-10 connector. Shield not grounded on vfd end.
I think this is the OMRON encoder you need. E6B2-CWZ1X
- CNC Control System Serial Number: 0479B7AC0CC0-0410203131
Thank you for the help I was wondering why it didn't have the a- and the others
I changed vi to ai which I should have done but it still didn't fix my problem with the vfd not changing speed based on the voltage
Do you have the VFD configured for remote input?
Omron Encoder Part number should be: OMRON E6B2-CWZ6C 1000 to 2000ppr should be fine for encoder spindle
Attached are my notes for a Huan Yang HY Series VFD (do a search on the forums for Huan Yan HY, been discussed A LOT on the forum.
Let us know how you make out and if the notes help you out at all...
- HuanYuang HY Series VFD Setup for 0-10v input 200731.pdf
- (18.31 KiB) Downloaded 113 times
I got it fixed had to use vi there's a pinout on the vfd it's backwards to the other models for some reason
I also got my new encoder today it's a 3600 ppr it should work thank you guys for the information that really helped me
There are actually knock offs of the Huan Yang VFD
Someone sent me instructions when I got it that weren't quite right for my model but the one Marty sent was what I needed lucky I figured it out later the day I posted this the instructions were kinda miss leading at first I've never used a vfd so I figured all this is a good learning experience.
