I think the o1-03 change is now displaying RPMSSword wrote: ↑Thu Jul 30, 2020 10:05 pm This is quite similar to my V7-4X, a couple things to check...
Main frequency reference - your 0-10v should be hooked to A1 (not where SB had the USB, that was for RS485). Reference section 3.7, 3.9.
Parameter b1-01 set to 1 for frequency reference.
Parameter o1-03 set to 2 should be for r/min units on the display. Reference section 5.10.
Other than making sure you have the 0-10v hooked up correctly and the frequency reference parameter b1-01 set, that should be all you need to change from the previous SB settings.
https://www.yaskawa.com/delegate/getAtt ... 060618.pdf
However, When I do M3 S18000 the VFD is only showing 9000
Which would kinda make since due to the fact that the RPMs sound lower than before
